OSOve volvicko v 40
Re: OSOve volvicko v 40
rozober svetlo a uvidis - su tam take klby po stranach - moze byt vypadnuta z nich, alebo su ulomene.
oso na repas poziciek kukni sem
http://volvoklub.sk/viewtopic.php?f=33& ... pas#p13118" onclick="window.open(this.href);return false;
a neviem ako je to u h7 svetlometov ale mne sa h4 podarilo zrepasovat myslim tie uchyty paraboly . zial tema uz bola zmazana
- Vek:: 25
skusim cez vikend staci to vykuchat z prednej strany, dat dole tie zaklapky a pojde to alebo je na to nejaky speci postupwickey napísal:rozober svetlo a uvidis - su tam take klby po stranach - moze byt vypadnuta z nich, alebo su ulomene.
2. VW Golf 1.4 44 KW 1997 AEX
musis komplet zdemontovat svetlo zhodit ciry plast a uvidis co tam nie je v poriadku
- Vek:: 25
nazdarek zacala mi svietit kontrolka service aky je postup pri vynulovani na v40? Diki
moznost 1:
Proceed as follows to reset the service reminder indicator (SRI):
Ignition off
Press and hold in the reset button for the trip odometer
Ignition on
The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when the reset has succeeded. The SRI indicator lamp goes out.
moznost 2:
Volvo S40/V40 Service Light Reset
RESETTING SERVICE LAMP ON 1999 S40/V40
1, Hold down the odometer button
2, Turn the ignition so all the lights come on
3, Keep holding the odometer down for 30 secs or until the service light starts flashing
4, Release the odometer button
Ignition off
Ignition on
moznost 2:
- Vek:: 25
dikes podarilo sa
- Vek:: 25
Je normalne ze Sa mi motor zohreje na 90 po viac ako 20 km, minulu zimu som menil termostat a bolo to zohriate daleko rychlejsie ako teraz, zeby bol zas v prdeli ?
- shreky517
- Poďakoval: 82 krát
Tak to ho máš v prdeli ja som dával originálny volvo termostat ráno dcéru do školy ja do roboty cca 3-4km teplota na deväťdesiat....a to nehovorím o tom kedy začína kurit....až môžem poradiť kúp origo... v autokelly chceli za termostat 27e origo z autorizaku tuším 32e ak si dobre pamätám a žiadny problém zatiaľ.....vyrobca je vahler
- Vek:: 25
Teraz tam je nejaky facet tak kupim ASI ten vahler
- shreky517
mozem odporucit ja zatial bez problemov ale ja by som bral origo z autorizaku darmo je to prvovyroba neviem ci vahler z autokelly bude to iste kvalitativne.....je tam fakt rozdiel par eur....oso napísal:Teraz tam je nejaky facet tak kupim ASI ten vahler
- Vek:: 25
shreky517 napísal:mozem odporucit ja zatial bez problemov ale ja by som bral origo z autorizaku darmo je to prvovyroba neviem ci vahler z autokelly bude to iste kvalitativne.....je tam fakt rozdiel par eur....oso napísal:Teraz tam je nejaky facet tak kupim ASI ten vahler
Nevies cislo dielu nemam tu vidu
- shreky517
myslim ze toto cislo hladas ....ty uz mas B4184S2 myslim ale ze to bude to iste....
- DSC_0051.jpg (121.46 KiB) 5385 zobrazení
- Vek:: 25
Dik sedi to
- shreky517
V pohode oso potom hoď cenu koľko pýtali od teba som zvedavý...
- Vek:: 25
mna stoji 28eshreky517 napísal:V pohode oso potom hoď cenu koľko pýtali od teba som zvedavý...
- shreky517
Super este o pár eur menej ako mňa neni čo riešiť nech slúži...
- Vek:: 25
tak termostat je doma uz len ho tam nahodit, skusal som hadicu do chladica a je furt tepla aj ked je rucicka teploty uplne dole tak hadam po vymene za origo to bude zasa ok
- Vek:: 25
tak termostat vymeneny auticko sa hreje okamzite po par km je na 90
- shreky517
Ja ti to zikal karle....
